Syncrowave
Hey, all, new guy here. I've been boating a long time but mainly in FG boats.
Just got a new alum jon boat (Lowe L1648) and I am rigging it, and I want to fabricate an aluminum box to attach the outboard control box to. The sides of the hull are at too much of an angle leaning outboard to attach the control box directly, because the lever would lean outside of the boat, so I plan to make the box triangular such that it has a vertical surface to mount the control box to.
I want to attach this box semi-permanently to the hull, and since it will carry some weight and be subject to some force when I move the control lever, I don't really want to use aluminum pop rivets, since they will probably get loose over time.
I'm considering using stainless steel machine screws and locknuts, but I am concerned about galvanic corrosion between the stainless steel and the aluminum hull, especially since I will be using the boat almost entirely in saltwater. Theoretically, since stainless steel is more noble than aluminum on the galvanic series, the aluminum may corrode around where the stainless steel machine screws go through.
What's the collective opinion on how to address this? Is it not an issue (even in saltwater)?
Or, alternately, should I use aluminum pop-rivets and back it up with 3M 5200 marine adhesive sealer to hold everything in place?
I would consider welding the aluminum box to the side of the hull, but I don't want it to be THAT "permanent."
Thanks in advance for any suggestions.
