Need some guidance/help.
I have a 2006 Yamaha 40 four stroke that stalls when I put it in gear and try to throttle up with it. It pees a good stream while idling and starts right up but will stall if I try to increase the rpms. I let it warm up for a few minutes, I've put fresh gas in it and new plugs. I checked the gap and they're the the same as the ones I removed, .030 inch. I've tried looking on line to see if there's a water seperator for the engine and haven't seen one referenced anywhere. I'm at a loss and I don't know what to look for to troubleshoot this problem. Normally I'd just take it to a dealer but the closest one is about 50 miles from me. I am mechanically inclined and know the basics of combustion theory but I'm not familiar with outboard engine operation. I would remove the carbs and check the jets to make sure none are plugged but I don't have any way to synchronize them if I took them apart so I've left them alone. I would think it's probably something simple that I'm missing. Is there a manual that I could reference for this problem?
Is anyone here that might know of what I should look for to address these problems? Any help is appreciated. I think it's kind of ridiculous that a Mercury dealer can't work on my engine, or any engine that isn't Mercury. I guess that it's just another way to gain market share. Thanks for any help folks.
