Steering wheel/motor question.
BenCoJared
My cousin is giving me a 10 foot flat bottom boat and I'd like to put a steering wheel on it instead of just steering with the motor handle. How do I know if a motor can be hooked up to a steering wheel? Bet you can't tell I'm new to this stuff, huh?
Yes - you will need to install either a hydraulic steering or cable system - you are looking around $500.00 for the components
I would not bother in a 10 foot boat
Couldn't the parts be taken out of the 10 footer and put in a longer one later? Edited to add: Can a hydraulic steering system be added to ANY motor?
I've never done it...so take this with a grain of salt.
Way back when ( I was young)...many boats had remote (drum equipped steering wheel) steering that used wire or rope cables. I'd check the Boston Whaler site for a reference. A number of the Whalers were rigged that way. It is called Continous Wave. Just do a Google and ask about cable steering.
Here is another reference LINK
https://forums.iboats.com/showthread.php?t=281025
R
Yes you probably could remove the steering system and add it to a larger boat. You should be able to add a steering system to most motors (very small under 10 hp maybe not)
I'm Instaling steering and controles in a 12 ft V, It is not as easy as one would think!
I am using a Teliflex no feed back steering systim so far i have no problems other than the cable is very stiff.
I found all my parts on Ebay some cheap others not!
Here is my thinking on a 10 ft Jon I would use a pully and cable system! I dont think you could get a Teliflex cable system short enough! Also with steering you will want throttle and shift controles of some type . I found an old Jonson control box with cables on ebay for 45$ I will make it work. all I can say is study up and start buying parts it not going to be cheap!
John H
