Bubba said:The lower PSI rating may have something to do with the Plies or your tire. I've read the 4 ply tires are usually only rated around 32-35, and the 6-plies are rated for usually 50. I believe my new ones read "50 PSI Max cold" so do I inflate them to the max?
I would keep them inflated as prescribed. The boat prep/mechanic guy at Tracker told me to keep the tires inflated to the recommended 50psi (cold). I usually inflated them to about 48-49 to leave room for heat expansion while trailering a long distance.
You're porbably correct on the ply thing. The GoodYear tires I had on my truck were 6-ply and the inflate pressure was 50psi. My new tires, which are 4-ply Michelin's are inflated to 35psi. When I get a chance I'll put my bifocals on and go check the trailer tires.
