Bunks for the trailer?theyyounggun said:Well tonight I went and picked up
x2 2x4x10
x1 2x2x8
x10 5/16" carriage bolts
x10 5/16"x18 nuts
I got started on painting the winch.
x2 2x4x10
x1 2x2x8
x10 5/16"x18 nuts
theyyounggun said:Thanks!
Im going to try and bust the lug nuts off and get them cleaned up and paint the rims.
Thanks. I was going to try the coke. I'll try and remember to do it early tonight.russ010 said:theyyounggun said:Thanks!
PB Blaster... or this stuff at Academy called Corrosion X in the little red spray can... If you don't have either one of those - you can always pour Coke (seriously) on them and let it sit for about 5-10 min... that should be just long enough to eat off the rust if that's the problem you're having
Usually. With the Minn Kotas, you usually just have to undo a screw, spin the control head around and put the screw back in, voila, BOW mount!theyyounggun said:I was looking and noticed all of the trolling motors say transom mount. Is there a way to make it work on the bow?
