I took the boat out for the 1st time yesterday. Since I have updated I finished reattaching all the sidewalls etc. And since i told my son we would go fishing the first day he was off for summer a couple of months ago I rushed the floor a little, I wasn't sold on the carpet idea and after our first couple of times out and the amount of trash I have gotten out of the boat it confirms it, I am going with something else in the floor, I like the carpet on the sides and tops and inside the storage, but i can't have it on the floor. I used just some of the cheap plywood and some of the reinforced fiberglass stuff that people use in bathrooms over the top. It took me about 4 hours including making the cardboard template to get the floors into place and we were off. There are a couple of spots I can tighten up the floor when I replace the cardboard as expected and I know the plywood will not last for ever but we keep the boat under the shelter so I think It will be fine to get some fishing done over the summer or until I find some aluminum or something permanent to go back with
1st trip out we noticed a lot of water in the boat and after filling the boat with water again when I got home, I narrowed it down to either the livewell or the drain hose for the livewell, since when we filled the boat water was coming out of the livewell drain and it should have been a closed system. anyway I plugged the livewell drain and then filled the livewell and it was the hose that was leaking I was pretty excited since that was a cheap fix.
went out today and there was no leaks and the boat ran well, it would start to act like it was struggling to get fuel when I ran it at full throttle to long, I don't know if its a fuel pump issue or just a bad seal in the fuel line somewhere. I would back it down to idle for 30 seconds and then its good to run again for 5 minutes or so. like the tank wasn't venting or something.
Very happy with it so far.
Still need to
- add a livewell pump screen
-finish rod lockers
-mount transducer on transom- probably going to go with the cutting board
-mount a trolling motor.
I also found that with the long front deck the trolling motor I have is too big for the boat, i thought about lengthening the shaft and the footpedal but its too much work when I can probably trade it for one that just fits...
