I fiberglassed my jetski hull to the aluminum on my jetjon and it is incredibly strong. I tried removing the epoxy from a section of aluminum that was not prepped and ended up using a grinding wheel and 15 minutes of labor to get it off, needless to say I was sufficiently impressed. If the aluminum is prepped correctly ie.. sanded with 80 grit sandpaper then cleaned with acetone the bond using epoxy is permanent. I would not utilize a fiberglass bond as my only means of jetski attachment, but used in conjunction with adhesive caulking and mechanical fasteners it just becomes another safety layer in the build....and its really easy to do.
In all honesty my next build will be welded in, no mechanical failure, no sticky caulk covered fingers...all I need is a $1200 tig welder!!
