ProduceMan
I have a short shaft Johnson 15 and a short transom. Cav plate still 1 1/2" below the hull. I have a chance to buy a static mount kicker bracket for cheap. Could I use just the poly mounting board and bolt it outside the transom to get the desired rise. The bracket is rated to 15hp. The poly board would result in a 2" setback. Good idea or no?
