Under cowl fuel line replacement. Help needed
Walli
Sask. Canada
I am changing the undercowl fuel line from the fuel pump to the carburators on my 115 horse mariner. I ordered some hose from the local Mercury Marine dealer and they sent me type B1 I was wondering if that is the right hose or do we need an A1 under the cowl of a outboard motor. I have searched through the Coast Guard regs and everywhere and nowhere does it make it plain what to use on an outboard engine. Any help would be appreciated. Thankyou
I'd use A1 if it were mine ... from J1527 SAE standard:
Ratings are determined on these two factors, permeability and fire resistance. Particularly with volatile gasoline, permeability is a concern due to vapor build up. If it is in an enclosed space "below deck" it must not give off explosive vapors. Manufacturers often refer to hose as "above deck/topside" or "below deck" hose, which is simply a trade gimmick way of phrasing the permeability rating.
The rating system exclusively for marine hose is known as SAE J1527 and it provides for grades as follows:
A1--fuel feed hose; has a fire resistant cover; is designed to have fuel in the hose at all times. Least permeable with highest fire resistance.
A2--fuel vent hose; has a fire resistant cover; is not designed to have fuel in the hose at all times.
B1--fuel feed hose; without fire resistant cover; is designed to have fuel in the hose at all times; intended for non-enclosed spaces. Diesel engines or above deck outboard gasoline applications.
B2--fuel vent hose; without fire resistant cover; is not designed to have fuel in the hose at all times. Diesel vent lines.
richg99 said:
Not sure if this is the correct procedure, but, when I have to install stiff hoses, I boil some water and dip the Hose end in before slipping it on. richg99
I've done that where I made a small jig and let it cool in roughly the position needed when installed. The jig was just some nails to hold the routing and pieces of strapping added to a board, for where it took a sharp 90-degree corner. Admittedly, yeah .... sometimes working on OBs you wonder how the heck they put it together!
Once had a bolt on an old V4 below the pan to remove ... took hours for what should have been minutes !!!! ; could only turn the bolt 10-degrees out at a time. I recall bitching about it on-line on the old WMI Forums and Dunk said he drills a 3/4" hole in the pan, uses a socket set to get the offending bolt out (and back in) then simply presses a 3/4" plastic cap back in place .... grrrrrrrrrrrr, and duh, wish I had thought of it. Neat idea though!
