driz
I picked up a 85 Tournament V17 last year with a nice 50 hp 4cyl 1983 Merc on trailer for $800. I plan on going through it but am not going to go hog wild tearing things apart, just the needed stuff. Anyways I used it a for a while last summer and it fishes fine. Lot's of smoke from the old 50/1 in the gas mix but then it won't fail and trash the engine either.
I did notice it seemed to go around 25MPH top end which seems a bit slow for a 50 on an aluminum boat but then it does have those hugely thick decks. the chairs mount on. It still seems Heavy. The PO has 4 bladed prop and a Stingray foil on it. I took the stingray off and the boat behaved pretty squirrelly. Stands right on its' tail unless trimmed full down and you just can't trim it up or it immediately rises way uncomfortably high. With the foil back on it's manageable for my use but I still wonder about the foam. Pulling the boat onto the trailer the little **** is almost as hard to lift up and pull forward as my big 23' Bayliner cuddy.
It has another weird bad habit water coming over the back right into the boat. I mean a lot of it. The boat always tosses a fine blade of water off the drivers side. It looks like the bow wave of one of those old WW2 Destroyers going full out. Just a fine clear blade of water that contacts the rear lift handle, all 1/4" of it and sprays it in the boat. I'm talking a lot of water. In 3 miles flat out I had enough back there that there was probably 35 to 50 gallons in there to pump out. Weird. It just flops over the side onto the edge of the rear platform and runs down the side into the bilge. But that's how it is. There is a small dent on that side by the seat but a couple pros looked at it and said no way it would do that, it's above the blister anyways.
This spring it gets some fix up. This just keeps coming back to weight. So with that and the infamous foam in mind where is the best place to probe around to see what's wet and whats not on a V17? I assume the back will be the major culprit. Just how do you tell, pulling out the drywell or plastic compartments and sticking a finger down into the foam I assume?
I also find the low console and windscreen somewhat useless. It seems a simple job to just put in a spacer piece on the top of the upright and raise it a foot or so Not super high but enough that I don't have to sit stooped over like Magilla Gorilla in that cramped seating position, I'm 6'1"
I have all the ninja skills, carpentry, wrench, painting, welding and the gear to do it I just want to know if I am barking up wrong trees in places or not before I start tearing things out. Ideas, criticisms welcome
