Not to mention that I like to enjoy dark beer. I‘ll bring three cans and usually spill half of it. ( Fish on! kick can over.)
This has been known to happen, d@m fish!
Does the brand of vinyl matter? What brand do you have that has lasted 5+ years?I guess it depends on how we define "much better". It doesn't hold moisture, fish slime, etc. Hooks don't catch in it. It is easy to wipe clean and lasts a long time. Mine is 5+ years old and still looks brand new. Vinyl even provides some protection to plywood flooring.
Vinyl likely costs more and might be more difficult to install than carpet .
Yup, that's where I got mine. Best price I could find.Nautolex marine vinyl, from Defender Marine, CT
I put down the Nautolex with the exterior marine contact cement and it started to curl along the edges after the first season sitting out in the sun. It has tightened up so at this point it wouldn't be possible to get the same coverage it was originally put down with. I think it really needs to be applied with some sort of fasteners to help hold it in place like if applying it to wood, wrap it around the underside and staple it there. I'm waiting for it to come fully unglued before I decide what to try next. It sure looked good when I first put it down and it does protect your feet from hot aluminum.
My boat has no wood to wrap it around so that wasn't an option. I do remember looking at a G3 CCJ boat that had the flooring from the factory and it had rivets help hold it in place on the aluminum floor. I didn't want to drill a bunch of holes to do rivets so I tried the glue by itself. Sitting exposed in the sun at the dock is probably the real issue.
Is it recommended to seal the plywood prior to applying the vinyl, and if so what is recommended? I apologize for the questions. I'm working on my first boat and would prefer to make it last at least a couple of years.That is how mine is -- wrapped around the plywood edges and stapled underneath.
Sure it is ... too late for you now, but you wrap it under the piece you're putting it on ...My boat has no wood to wrap it around so that wasn't an option ...
Get the Epoxy Starter Kit from www.raka.com or fiqure out how much square feet you need and call Mike @ www.raka.com and he'll help you out ...Is it recommended to seal the plywood prior to applying the vinyl, and if so what is recommended?
There is no edge to wrap "under", it just lays flat on the floor. I did add some aluminum angle on the front of the rear boxes to hold it down. I drilled out the existing rivets and put matching holes in the angle and riveted them down. But there is no way to do that up front on the deck or on the main floor, they are welded along the edge of the boat.Sure it is ... too late for you now, but you wrap it under the piece you're putting it on ...
Thanks. I'll look into this.Get the Epoxy Starter Kit from www.raka.com or fiqure out how much square feet you need and call Mike @ www.raka.com and he'll help you out ...
Soak as much into the edge grain as it will take and that floor will out-live you!
I think he had a modern boat with aluminum floors that are welded in place. Some floors you can't remove, as they are part of the structure.Sure it is ... too late for you now, but you wrap it under the piece you're putting it on ...
