Ok... so here are the updates (is it really 12:30am??, I gotta start keeping an alarm clock down there).
Anyways, just some basic framing for now. I am still not done, I'm going to have a good many compartments on this part of the deck.
One for each battery which will open up towards the bow. Then in front of each battery there will be another. Here is where I'm going to keep my plano boxes. The lay out of the boxes is pretty much the direction the hatches will open. Hatches in front of the battery will open towards the sides of the boat. In the middle, I haven't quite decided if I'm going to do one or two compartments... most likely 2. I'm going to store my life jackets, tool kits, and all that jazz where the radio is. This is my new radio setup by the way - I now have Sirius satellite coverage for those long days :roll:
On the deck is the "B" grade Hydro Turf I bought months ago. This took one roll, and I still have another one left over. I'm going to carpet the deck that I'm framing. I put this stuff down with 3m spray adhesive and I don't care if I EVER use that crap again.
I also got a new trolling motor mount. The Gator Flex 360 is what was on there... and it's just not strong enough to handle that 71lb thrust motor. The new mount is the Tour Gator Spring - and holy smokes is all I have to say.
I decided to redo the old 2x10s I had as a temporary mount. Well... I'm still using it, but I did a little modding to it. I cut it down to fit the mount, then carpeted it. I also set if more towards the middle because I wanted to be able to keep 3 rods on each side of bow while fishing (kinda like the pros do, even though they have a helluva lot more room up there). I finally found my rod straps and put it on there too... If you look in the back of the pics, you'll see one of the Hella lights I have installed and the new Ram mount for the HDS unit. It took me forever to run all the wiring... the foam under that front deck is crazy.
I wanted to put in a recessed foot tray, but I can't... there are 2 4" braces running down the middle which is the support - so it's going to have to stay on top unless I can figure something out - I might come up with something yet.
