jtf said:
Guessing there wasn't a spray in liner? Think I'd like that matting better as long as it stayed cool in summer.
no sprayed on liner in mine, it adds weight. The turf flooring is lighter, grips better, more comfortable, & stays cooler in the summer. The 2 downsides compared to sprayed on liner is that the turf is a little harder to clean & a little more delicate. it's also cheaper & not that hard to replace though.
jtf said:
would you suggest deleting the wiring and getting it done aftermarket?
If you got the money, 100% yes. gonna be about half the cost to let the factory do it though.
well that $70 umbrella is on the bottom of the river, good gust bent the pole, it sheared off & sank before i could whip around & get back to it. will probably buy another & cut the pole shorter & reinforce the inside of it.
got my lights installed finally, might see if the welder can build a cage for it at a later date, but loving the setup. horn quit working so tossed the switch in the garbage since i have a whistle & put the LED driving lights switch where the horn switch used to be
i just joined the red/black for the 3 lights so all are on at once, used 16 gauge tinned marine wire for the run from the lights to the battery & console, these are about 2/3 the wattage of my 1546's LED setup yet work better because of the way they're aimed. the spotlight firing forward is 6.5" wide & 36 watts, the 2 spreader lights firing sideways are 24 watts each & the beams are combo so every other bulb goes flood/spot/flood/spot/etc. & they do a great job lighting up the river banks. it's also less blinding than the 108w setup on my last rig when you're in tight back creeks, but it still throws way out there to light up channel markers in the distance:
