1860 tracker grizzly
I ordered the tank through BassPro Todds angler 30gl https://www.basspro.com/Todd-Angler-Series-Baitwells/product/30208/?cmCat=CROSSSELL_PRODUCT_MTv2 After the tank arrived I measured it up and made a stand so my over flow drain could hang on the side of the boat. I didn’t want to have to drill a hole in the side of the boat and I wanted the tank to be removable if I just wanted to take the kids out riding. After I got the stand done it was a matter of getting all the small pieces together. Here is some pics. If you have any questions about let me know.
    34.2 KB
    42.2 KB
    40.5 KB
    49.4 KB
dwbiggs said:
How did you run your wiring from the front back?
I ran 16ga tinned marine duplex wire inside the side rail tubing with a fish tape. Had to drill a 1/2" hole which I then plugged with a 3/4" rubber stopper plug from the hardware aisle @ Home Depot:
Awesome. I didn't even think of doing that way. The tubing already has a hole at the transom for a drain so if water did get in it would drain out anyways. Is your boat a cc or sc? How did you then get the wires to the console?
I’m looking to get a trolling motor for my boat but not sure what I want. I mostly do salt water fishing so the salt water series is the one I need. Any preference of brand? What shaft length do I need? I am going with 12V just because I won’t be using it a lot just mostly for gigging and they are cheaper than the 24 or 36V.
