1969 15' nader v hull
ahain987
iowa
I am new to posting i have looked at alot of the posts on here. I have found some really great ideas. i have a couple of questions
1 the is a tray on the back end of my boat can i remove it? if so what should i do about the two holes on each side(last picture)
2 i have a couple if rivets below the water line that leak a little some one told me i could hammer them with a hammer holding it on the inside and the will reseal
pictures
    157.9 KB
    139.2 KB
    122 KB
    205.6 KB
this is what i am think about doing to it. anything i might be over looking
    13 KB
i am in need of some who can help me with my rivets. i need to know if i can hammer them so they will seal again or do i have to replace them
That's a splash well, I would not remove it. Yes you can reset the rivets by hand. Best to use about a 1/2 inch solid aluminum or steel rod against the rivet head then hit it with the hammer two or three times. Have someone else hold hammer against the other side of rivet. I use a 4 pound sledge hammer. Check for leaks again, if it still leaks do it again. Good luck.
finally got started on the boat today
    642.4 KB
    633.5 KB
