baseball_guy_99
An input on if I adjusted the shift lever correctly?
baseball_guy_99 said:I finally did something right! Ran the motor all morning and into the afternoon and it didn't kick out of gear once! Top speed was 22 but I didn't quite crack it all the way open.
[url=https://www.tinboats.net/forum/viewtopic.php?p=259681#p259681 said:baseball_guy_99 » 27 Apr 2012, 20:21[/url]"]
Pappy I still am unsure of how you are talking about adjusting the shift linkage. So what I figured out was that if I lined up the clutch dog and the rear gear lobes, loosened the two screws, and applied slight pressure to the shift lever towards reverse, that the clutch dog felt to be more snug/tight against the front gear. Is this what you were talking about Pappy?
