1980 9.9 model E10RCSE
Motor starts in 1-5 pulls on water hose with choke half way out. If its really cold out it takes more choke but still fires pretty easily.
I store the motor in the run position.
When I travel I tilt the motor. It is tough if not impossible to start at the lake when I get there. After an hour of riding around with the electric motor for a while the 9.9 will fire and run fine.
I assume too much gas is getting in carbs while traveling?
How can I correct this issue?
Thanks in advance!
Thanks in advance!
