Wallyc
Greetings folks!
I was blessed to be given the motor boat and trailer of course the boat and trailer are not worth anything. The motor I was hoping “fingers crossed here “ to get it breathing again. As these are work horse motors and have had a few lower horse powered rudes however never quite like this. I have a couple of questions as I’ve never dealt with a motor basket case like this.
So far I have checked compression 125 both Cylinders.
No water in the lower unit. Could use a change. Motor has VRO which had problems it was bypast and a burnt electric plug so rather than deal with it I will be using a normal no vro fuel pump and new fuel hoses. Need to find a new/used air silencer.
I have decided to pull the t-stat cover and glad I did . It was plugged with crap on the back so I know I will be looking at a new water pump kit .
The last major problem was the tilt tube. Yep ! Frozen in the up position so I finally got it to come down. The motor has an assist clynder but it’s all assisted out.
So now the questions
1- can I get a stern bracket assembly with power tilt and trim from a early 90’s where the ram and motor are in the middle of the stern bracket instead of on the outside the stern bracket.
2-should I leave out the t-stat and run the motor and flush the motor good before I put the new t-stat in ? I’m a little worried about filling the new thermostat with trash or is there someway I can clean it out with while I’ve got the back of the thermostat cover pulled off.
3- anything else that I may have missed ?
Thanks for any help guys!
