A friend and I are rebuilding his boat and he's trying to keep it the same or close to it. We've got a nice start on the transom and deck with help from lurking around here.
There are a number of trim boards on the sides of the boat and near the transom that are plywood covered in a wood grain finish. It may be vynal or some other similar material that appears to be applied to the plywood or MDO board.
The lumber supply can offer veneer sheets to glue to the plywood but it seems a little pricey when you get done. Is there an good way you've used to get a wood grain look applied to plywood? Is there a good application guide?
Thanks, Paul
Thanks, Paul
