i have a 1989 basstracker tournament 1800tf with a 110 hp evinrude. sometime everything works perfectly and othertimes I have no power to trim or start. the batteries are all fully charged and the outboard is charging the batteries.if you are cruising around the lake the volt gauge will drop from 14 to 10 and you will have no trim or start. when you put a voltmeter on the battery it say 12.6. I don't know where all the wires go or what volt they should all be at. Any suggestions or advice would be appreciated.
Thanks for reading.
Neil
Thanks for reading.
Neil
