Ebug said:Gunz, the standard Mercury side mount shifter can be used on the side of a console. You remove a single bolt that holds the arm on, move arm to other side, and re-install arm. Done.
Here's a picture of the throttle I am talking about.
riverrat717 said:Ebug said:Gunz, the standard Mercury side mount shifter can be used on the side of a console. You remove a single bolt that holds the arm on, move arm to other side, and re-install arm. Done.
^^Exactly. :beer: If you want all your cables exposed.
Cables run inside the console with this one. Less to get hung up on, cleaner looking IMHO
