nice, got any more pictures of that deck hatch? did you dig out all the foam? i am wondering what it looks like under my foam, i want to put in some rod holders, but i want to be sure I plumb them for drainage to the weep channels so the foam doesn't have water just sitting on it from the rod holders. i'm 1/2 way there though, i coughed up $10 for em:
dwbiggs said:
Nice...like the yeti...what size is that?
45 but i would have gotten a 65 if would have fit under the deck of my flats boat, too big though
dwbiggs said:
You happy with your motor? Looking around for a used motor...2 stroke of some kind.
couldn't be happier.
40hp Toha 2-stroke look like a good fit for this hull @ 206lbs with short shaft, power trim, & electric start
25hp eTec 2-strokes also look good at 150lbs with short shaft, manual trim, & rope start
a used Yam on craigslist would b much cheaper though...
got me a new trailer for the flats boat:
swapped a few parts & she fit like a glove. the bow stop had to be changed from flat/skiff style to fit my vee hull, & the 8" bunk brackets had to be swapped for 10" brackets in order for the chine to clear the trailer cross members.
i added some scrap leftover turf to the tongue as well:
