Sounds good, thanks for the tips. got my floor and hatch installed:
i decided to seam the floor. was able to cut the seam free hand using a razor knife following the lines of the material. after covering the floor, there was not enough material left to run the front deck the same direction as the floor so I'm considering running the turf on the deck with the lines running left to right versus buying another sheet... definitely going to need more of these tempress cam hatches, they're great
the floor is narrower at the front versus the back so i took my time to measure & cut the edges to match the slant of the hull side:
scuffed the painted aluminum floor with 40 grit on the orbital then cleaned it with acetone prior to installing the turf:
below shows the seam of my 2 piece turf floor in the center of the picture. 1 piece is about 39"x67" and the other piece is about 7"x67", did my best to square up each piece at the seam & match the grooved lines pattern so it hopefully looks like one continuous piece of turf on the floor:
I was able to fit 3 life jackets and my anchor behind the 11"x15" cam hatch in the new bow storage area. the cam latch on this hatch is great, it's nice & tight. tempress recommends screws, but i had pop rivets laying around so i figured i'd try them out & they worked great. one benefit of rivets is they make it harder to steal the hatch. i put a nice bead of black silicone down prior to pop riveting. the hatch door stays up when open, kinda lucked out on that part:
both tempress & blacktip jetsports have the same idea of dark gray, glad they match but would be nice if they were darker gray:
tempress includes a handy template which i traced out with a red sharpie, but the template they sent me was actually too small so be sure to check that first. i added about a 1/16" to the template size & the hatch fit perfectly. planned on using the angle grinder initially, but there was plenty of clearance so i cut the hole with a bi-metal blade on the jig saw after drilling a 1/2" hole at each corner:
once the hole was cut to fit the hatch, i marked the mounting holes & drilled them with a 1/8" bit followed by the 3/16" bit for the medium 3/16" aluminum pop rivets.
