Nussy
Wow now you need the boat since your moving from Ice Fishing territory!!!
Nussy said:Wow now you need the boat since your moving from Ice Fishing territory!!!
danmyersmn said:ok, one of my soon to be final updates for a while. I have been holding off on starting my decking/wiring/plumbing/etc. because I was contacted about a job prospect. That prospect went great and now I am moving to Charleston, South Caroline before Feb. 1...
danmyersmn said:so it begins again. I finally have the boat out of storage and into my garage. Painted the interior and am ready to finish up the plumbing, then electrical, then decking.
https://www.tempress.com/store/index.php?cPath=12_69&osCsid=u7abapstrjrdi9e7sb5vo9p4i4benjineer said:I like your boat. That's about what I'm shooting for. Wish mine were that deep. What did you use for the livewell liner?
89Suburban said:Is that bow light LED also? I LOVE the extension cord reel used for anchor rope idea, awesome!Good job man!
danmyersmn said:A few days back I started filling holes in my hull. I have lots of them from the previous owner and his love for attaching stuff.
So....drill out pop rivits and clean up the metal.
Add Acetylene and Aluminium brazing rods.
Plug the holes. Notice I got too hot with the Acetylene and started to burn the hull. I suppose that's the down side of using free gas. My fishing partner is a master plumber and had this tank. I was out of MAPP gas and didn't want to use propane so i opted for the Acetylene. It will clean up though so it's not an issue that I feel needs further attention. I added material with the rod to fill from both sides of the hull.
The repairs are cleaned up using an 80grit flap wheel and I gave them a skim coat of JB Weld on both sides to fill any pin holes and block sanded it with 400 grit. This is enough of a repair for what I need. The repairs are likely to still be noticed under the paint when I am done. Even if they are. I am not planning on filling every scratch or banging back every dent. This is a 10 footer fishing machine not a brand new show stopper so its more about function.
I filled 10 holes. I still have 5 I believe on this side then I can go to the other side. The transom has 6 holes in it from various trolling motors but I have a different plan for repairing those. Now I need to put everything back together and prep the boat for this weekend.
