danmyersmn
Hydrilla said:Looks great! Looks like the same color as mine. I dig it.
What paint did you paint yours with. This is what I am using.
Sand on the bottom, Hunter Green on the top. Sand on the inside.
Nussy said:Great paint job. just curious did you roll and tip or spray it on?
VBTravisD said:You might have posted this... how many coats or primer and color did you use?
VBTravisD said:This may sound rookie... but what is the benefit of thinning? A few of the areas I fish I worry about rocks or gravel scratching the hull. I am using the same paint (just OD green)...
VBTravisD said:I hear ya man... And it does look great! Best hing about using rustoleum... you can get it for 8 bucks at any hardware store.
CRAPPIE_SLAYER said:OUCH! That thing must have been moving! Had a bunch stick in me when I was stripping the trailer, but none deep enough to be cut out.
Nussy said:OK, just thought you new something I didn't.![]()
I used spray rustoleum on the outside of my first build and I think it's scratched pretty easily . That was after 4 coats, sprayed about 20 minutes apart as directed. On my new build I was thinking about rolling it on like you did with the 10% thinning...but I also want to paint the inside which might be tough to do with a roller. So I was hoping I could spray the inside to match.
Decided to call Rustoleum. According to their customer service the paint in a spray can only slightly different than the regular stuff. She said they have same finish qualities and durability and should match from a color perspective. One thing she did say is not to use any rustoleum paint(including their boat paint) below the water line on an aluminum boat. She suggested contacting Pettit which is their sister company. I think the Rustoleum would probaby be fine as long as the boat isn't sitting in the water all the time.
