I was almost done putting my boat back together when I thought of doing one more job.
I have never been able to turn the motor off by turn the key to the off position, I have always had to pull out the safety switch and today I decided to fix that.
I figured there was a loose wire or corrosion on the key housing which was preventing the motor for turning off via the key.
So I opened up the side mount control centre and I found a loose wire with a rubber boot next to the key housing and I found a screw on the key housing which did not have a connector attached to it.
I figured the loose wire was supposed to be attached where the screw was. Once I attached the wire and turned the key the motor would not go on.
So I detached the wire and tried to start the motor but it won't go on.
I can start the motor with a pull cord and it will run fine and I can shut it off by pulling emergency cable out.
But at this point I can't turn the motor electricity. If I turn the key there is no power to the motor and it does not turn over.
I checked and the starter battery is fully charged.
Is there a fuse in the control mechanism?
Any suggestions would be appreciated.
![IMG_0978.JPG IMG_0978.JPG](https://cdn.imagearchive.com/tinboats/data/attachments/78/78548-0b54f4e80df93f678bbffbeff58bc17b.jpg)
![IMG_0979.JPG IMG_0979.JPG](https://cdn.imagearchive.com/tinboats/data/attachments/78/78549-f135147468545ca4a26008e9abdd801c.jpg)
