Alumacraft 1648 (updated 9/13/11)
Mod looks great. How did she float, any leaks?
Doug - floats great, 2 small leaks when I went out by myself. One rivet and a seam about a inch long. Both on the bow. Took on about 1/2 gallon in 4 hours. Not much on a 1648. When I went with my friend it took on no water because it lifted the bow up a bit with the added wieght on the back.
I did learn that I will need to lower and widen my trailer bunks. Tin sits to high, had to bring my rear truck tires to the water edge to load boat.
Did you have to thin the parkers paint to spay it? If so, what did you use and how much? Thanks!!
Yes, about 10 to 15% and I used paint thinner. Been working on lowering the bunks. As you can see in the pic's it sit's too high. Don't know how the previous owner managed like it is now.
GREAT JOB and nice looking boat...
I have a 1648 alumacraft ....... mine on the other hand is much older...
STILL in great condition.. just older.....
SO I AM CURIOUS on the nose of your boat.. you replaced some aluminum...
would you please tell me what size you bought ? were you bought it? and how
much was it....
I cant really tell in the picture... as to the size... I am assuming is a piece of Round
aluminum tubing?
thanks so much...
Stacy Warner
Parts/Accessories & Warranty
Warner's Dock, Inc
1020 N Knowles Ave
New Richmond WI 54017
888/222-3625
https://www.warnersdock.com
I'm thinking it was $30 for a 6 foot piece and $30 to ship. They bought it from Alumacraft and had it shipped direct to me. For me, it was worth every penny since it changed the look of my tin to a much cleaner look. It was a big concern when I bought the boat but was a easy fix.
Oh yea, measure your top rail and send a pic to Stacy with your HIN so Alumacraft can match it with your tin.
More pics, still have some more mods to do but I am very comfortable right now
    216.4 KB
    180.3 KB
    172.7 KB
    152.9 KB
    179.5 KB
    196.9 KB
    162.5 KB
    300.2 KB
    311.3 KB
    327 KB
    245.6 KB
    237.5 KB
    211.2 KB
    237.7 KB
Great mods! Quick questions did you rivet in your cap on your transom or weld it? Mine is cut from the previous owner in a rectangle and im wanting it to be more like yours to give my tiller more clearance.
Thanks and great job!
I would have prefered to weld it but I did rivet it and it holds up fine. I have since added a 5/8 board to the inside to accommodate the throat of my 15HP
You wouldnt' happen to have a link to the exact wheel/tire combo and or the hubs you bought on northern tool would you?
I've been looking, but i'm not sure if i'm finding the correct ones.
Funny you ask, on my way to NT today because my outer bearing fell apart as well as the inner ring on hub that holds the end cap on. Not sure wht the heck happened, only about 1000 miles on it. I will try and get some item #s for you.
