SPLASH
She's been splashed :mrgreen: Where to start... I pulled up to Shields right at about 9:30 this morning and Brett the owner was finishing things up and just had to connect the water pressure hose. Brett is the owner and NOT afraid to roll up his sleeves and go to work and he did a GREAT job and I'm very happy with his work. Truth be told, he rigged the entire boat and did an outstanding job of it. By about 10:30, we rolled the trailer down the ramp. I went through a few things with Brett and cranked up the Etec. First thing I noticed was how unbelievably quite this engine is. These are not by any stretch grandad's old smokey 2 stroker. I've owned a few 4 strokes and a 2 stroke Yamaha over the past few years. This engine is pretty much just as quiet as the 4 stroke 90 Yamaha I had on the G3 1966 and that was a quiet engine. I motored away from the dock through the no wake zone for about 1/2 mile until I got to the channel marker and then I was good to go. I gave it a bit of throttle and I was really surprised how fast it got up on plane. These engines get up and go. I left the tabs up and out of the way on the first run up the channel. The boat itself is a beast. I've owned 3 G3's since 03 and always read how good SeaArk's were but had never ridden in one let alone drive on until today. The boat itself is actually a little lighter than the 1966 I just sold and I'd always wondered how it would run out with the weight always on my mind. I got my answer. The boat is incredibly stable and tracks true and runs straight as an arrow. There was a slight chop with no ill effects on the ride. In my G3, I'd have lost my teeth. Every G3 I owned beat me to death and pounded like no tomorrow no matter what.
On the first run with no tab, once I looked at my speed on my cell GPS I was running about 30 and noticed the boat wanted to porpoise a bit. I ran up river about 2 miles varying speeds etc all with no tab. Right about 30 on each run, the porpoising would start. Not horrible but it was there and worsened slightly as I gave her more throttle. These boats are known to porpoise and I thought it would be worse than it was but now it was time to test the tabs. On the next run, once I reached 30 she started to porpoise so I gave her about 1/2 tab and whoo hoooo. She settled right down and the porpoising totally disappeared. Prior to using tab, I varied speeds quite a bit and was looking for some stern squat with no tab. There was none and that I can attribute a good bit to the prop which is a 4 blade and it really got me out of the hole and pretty darn quick. I've got a LOT of weight in the stern and just forward are 2 more batteries so this had been weighing on my mind pretty heavily and I'm relieved. The steering was tight and it'll loosen up over time and use. When Brett mounted the engine on the Weldbuilt that mbweimer has, it showed 12 hours so the boat itself has a whole 12 hours on it.
Back to engine for a second... as I said, I varied the speed greatly just to see how the boat handled as it's the first time I've run it. While I was really tempted to give it all she had, I didn't. I got up to 3/4 WOT and then backed down through the range and back up several times.
The boat doesn't have a traditional speedo but at 3/4 WOT, the GPS registered 45 mph and I didn't check that until I got back to the dock.
I knew I was going pretty damn fast but just wasn't sure how fast lol. The boat handled absolutely flawlessly and absolutely zero issues.
Through the process I tried to plan it all out step by step and take my time. I believe in doing things once and doing it right and if you can't do that, don't do it at all. It's all downhill from here thankfully and there's still a good bit of work to be done. The SeaDek console pad has been ordered which will sport the name of the boat and that will be disclosed once I receive it.
Snapped a few pics of the business end of the boat and the console. Funny, Brett made the same comment on the Linex that I did. He too imagined a miserable time cleaning up that pretty white interior which got pretty mucked up. He told me "I was really surprised how easy this stuff cleans up"...
Time to rest for a short while and set the plan in motion to finish her up.
With that, Bagger out.
