Zum
I'm going to delete my post then....wouldn't want anyone to try it.
scoobeb said:Ok,so after looking over the motor a bit I decided to play with the new toy for a bit. So what I noticed was when I was pulling the pull rope the engine would pull smoothly and then sometimes it would lock itself like I was trying to pull it in gear but it was in N the whole time,I found that odd. I put engine oil in it and I just was pulling it in my living room to see how hard it was to pull and it was difficult. I don't know if new outboards do thst till gas is in them then maybe it pulls easier,I don't know but I will find out today when I go buy 3 gallons of gas. From every video I have watched this motor was so easy to pull start. Is this normal? It says pull till you feel tension then pull firmly,I did that and a few times like I said it would like the rope and just wouldn't pull. I will have to put it to the test in about a couple hours. I will update how it runs and shifts.
I'm also draining the lower unit oil and replacing it with royal purple synthetic lower unit oil so the lubrication is superior right from the start. I know it must be changed again at 20hrs but I want the best protection on those lower unit gears as I can get from jump street so this is what I'm going with. I know,no matter whatit needs changed in 20hrs and it may seem like a waste to people to use expensive oil on break in but it's only 12oz of oil were talking here and I have 4 full bottles which is a gallon so I have near 12 lower changes worth of oil which is like 6yrs worth at 2 times a yr so to me it's fully worth it and I have a ton of oil so why not go with the best protection from the get go. Ok I will update the pull rope saga to see if that goes away when I fuel it up,man I hope so.I
Zum said:Those are really good numbers.
My 1652 only weighs 360 and with a 30hp only gets 27/28 mph..it does have a jet tunnel though.
I'd be interested to know what his rpms are, going that fast with a smaller pitch prop.
scoobeb said:If I achieve anything near or over 30mph with 3 people that will just amaze me.
