[url=https://www.tinboats.net/forum/viewtopic.php?p=355239#p355239 said:red450r » Yesterday, 7:30 pm[/url]"]You got your boat back? I read somewhere you had some bad luck
No, all foam does is add weight. Many people will argue but physics is constant. A pod full of air will be more bouyant than the same pod filled with foam. If water happens to leak into the pod, then and only then will the foam help anything.red450r said:Smack did you put foam in your pods?
