great white
- Joined
- Jun 15, 2011
- Messages
- 308
- Reaction score
- 0
Only half a days work today. Built the "rear wing box".
I ditched the aluminum framework idea. Just wasn't going to work out properly.
Took a while to figure out how to make it on top of the seat deck and fit it under the rail so the set deck was still removable.
but now I just pull out 3 screws and the box lifts off, then the whole seat deck comes out.
So far, none of the wood is actually attached to the boat.
It's all friction fit and laid out to rest under existing structure at it's edges. I didn't want to compromise the hull/ribs in any way.
The only thing actually attached to the vessel are some aluminum angles attached to the seat boxes to rest the floor on.
The fish finder is a portable, so I just wanted a place to hold it. Hey, it was free and it works...it's also self reliant on it's own batteries and easily removed so it won't get stolen.
The opening in the rear is just a stuff area. It will have a stretchy net over it to hold things in.
Throw in a cup holder and call it done.
The small solar charger will sit where you see it in the pic.
I'm up to about 1.5 sheets of 3/8 plywood and 2 2X4's in the whole thing so far. I'm very sparing with the plywood and I rip the 2x$'s into 1x1.5" stringers. All clamped, waterproof wood glued and screwed.
I should only have about 2.5 sheets of plywood and 3 or 4 2X4's in the whole thing when done. I'm going for "light" construction but still done to my preferences in a small fishing runabout.
The boat used to plane really well and I'd like to keep it that way.
More work tomorrow....the other "wing box" should go much quicker as I now have the pattern and the angles all worked out (everything is written down).
Hopefully finish off the rear decking area completely.
