great white
- Joined
- Jun 15, 2011
- Messages
- 308
- Reaction score
- 0
Only got another half day to work on the boat today.
Took a fair bit of figuring to get the front supports laid out in the configuration and spacing I needed while still supporting the deck right out to the edges:
Lord my garage is a mess! That drives me freakin' nuts!!!
Still, it's better than working outside in -10c and 3 feet of snow.......heated and insulated, that's the way to go boys!
:LOL2:
The forward deck is a bit more "conventional" construction compared to the way the stern was built.
The two center beams are a full 2x4 for strength since the span is long. I stood on them today and bounced the trailer up and down without deflection.
That'll do!
I had to make a notch cut in the ends to have them sit on the seats. The front seat is at a different height so the cut is different front to rear. I made the notches nice and tight to the seat ends, so it will keep the platform from moving for and aft.
The cooler is visible in the picture and will be on a platform hung from the deck in order to make it level at the top. Don't get excited, the cooler isn't for fish.
It's for my lunch!
8)
I'm usually catch and release if I fish recreationally. Might go barbless this year as well. Fishing is really just an excuse for me to go for a nice nap anyways...
There will be a hatch in front of the cooler and the battery will be under the hatch. The battery will also hang on a platform from the deck.
I'm following the theme from the rear deck area; everything will lift out and nothing will be attached to the hull or ribs. Everything is supported by the seat boxes, like the OE intended the weight to be supported in the boat.
There will be a small angled hatch on either side for misc storage (ie: life jackets, nets, etc) and that will all just sit on the hull on some foam floor pads.
There will also be a compartment built on the front seat in order to house the anchor and anchor line.
It's coming together, slowly but surely...
![d8ad29f7-1.jpg](https://proxy.imagearchive.com/01a/01a34c77573256292393c0ff36224a23.jpg)
:LOL2:
That'll do!
It's for my lunch!
8)
