OTW-102
I was wondering that myself - is marine grease rated for high-speed use?
I haven't taken a tube of it and compared it side-by-side to wheel bearing grease to see if the
engineering certifications match up. Has anyone else actually done this?
My father was a mechanic all his life. As a young teenager, I watched him change the bearings in one
of his old homemade boat trailers. He mentioned
High Heat Specific grease for trailers. I asked "why"?
He said - - - picture a truck with 17" wheels, pulling a trailer [any trailer] with 13 or 14" wheels.
The truck is going 60 miles per hour - sometimes for hours and hours on end. ........
that poor little old smaller trailer tire may be turning at 140 miles per hour - for hours and hours on end.
THAT is why you see so many boats parked on side of the road with burned up hubs.
So, with this in mind, I am quite sure that grease companies put quite a bit of research
into a specific lubricant that is designed for a specific application.
Whether it is for your Outboard Lower Unit oil, two-cycle oil, or trailer bearings,
I find it wise to use a specific lubricant for a specific purpose if you expect long term satisfaction.
Jus my dos centavos
