MrSimon
Jeffrey said:I like fishing the saltwater bays along the mid Texas coast. The Vee is better for crossing the open bays and the flat bottom is better for the mud flats and marshes. The Vee is safer and more comfortable while on the open water and the flat bottom allows better access in the shallows once you get there.
The Allweld boats you linked in your first post are actually mod-v jon boats, not shallow V-hulls. I believe that all of the responses have been comparing mod-v and flat front jon boats .... nobody has weighed in yet on an actual shallow v-hull boat.
I'd say a light weight shallow-V can run pretty darn shallow if there is enough weight in the front to balance things out. If you look at the bottom of a lot of shallow-Vs, they are perfectly flat, but the bow (which is above the water line) is in a wedge shape. Although, these boats tend to be narrower that jons and therefore will ride a bit lower in the water.
