midwestfisher
- Joined
- Oct 20, 2012
- Messages
- 35
- Reaction score
- 0
So, just got a new prop for my 2005 Johnson 115hp 4 stroke. (Thanks fuzzy grub). It is a Solas with a hub kit.
So as I removed my original prop I found this on the prop shaft behind (at the motor side) the thrust washer. (See pics it's the white what appears to be a spacer or something)
My question is should this stay on? Or was this for the original prop.
Neither the new prop kit notes this nor can I find anything that shows this with any other recommended prop without a hub kit (pressed in hub).
Got any ideas...on or off?
Help.....
Randy
Help.....
Randy
