Panthrosan
- Joined
- Jun 11, 2013
- Messages
- 7
- Reaction score
- 0
I've been reworking and fixing up my 12Ft Sears Gamefisher Jon boat and today I hit a snag. I had my new transom cut out and the two 1/2 inch plywood pieces glued together and when I clamped it back into the boat to drill the holes before sealing up the wood and I really thought that I had drilled the holes even and level but when I went to test fit the 1/4x20 bolts to attach the transom every hole it seemed was canted off at a different angle and as a result I have to scrap the transom and start over again. Any pointers on how to get the transom drilled straight? I was thinking of putting the new one I'm gonna cut up and clamp it as before but instead of drilling I will use my pencil and center punch to mark the middle of each hole and then take the transom off and use the drill press to drill the holes completely straight and level. I figure that with the holes on the plywood straight and level once I clamp it back to the boat, the 90 degree hole should match up with the angle of the aluminum back of the boat and the bolt will pull the transom and aluminum back together even and straight as well. Thoughts or suggestions?
[youtube]9BmwxDQ1yB8[/youtube]
