fireshadow
just got the phone with fasco and I have to say that they have some of the best customer service i have dealt with in a long time. Totaly makes up for not being able to pay buy credit card.
sixshootertexan said:Ok it seems that everyone mixes small amounts at a time while applying steelflex. I got 5oz dixie cups to measure from. 5oz from each container for a total of 10oz. 2 questions.
1. Does this stuff set up that fast or is it that hard to mix? (viscosity)
2.What's the most recommended amount to mix? I'm a one man operation around here.
PS I'm getting all the tools that are recommended in all post I've read.
levron41 said:If i was you, I would steelflex from the outside and hit it with some 5200 on the inside. It seems to me that steelflex would stick to anything! Let the experts chime in but I really think steelflex would stick to ice :roll:
sixshootertexan said:One more question.
Is it necessary to apply 2 coats?
tfizzle172 said:Okay, so, besides using steelflex on the outside cause we don't want it to chip.....what would be next best/cheap thing that will last for awhile on the bottom? Troutman I know you said it will chip, but how easily? and has anyone else been rough on their steelflexed bottom and had it stand test of time? If not steelflex then what should we use?
Thanks in advance,
Fizz
Howard said:My 2 cents: My tin had leaky rivets and a couple of serious splits in the hull and gussets.. I had the splits and leaky rivets welded. I then applied steelflex to the hull. I now have zero leaks. I personally would not rely on any epoxy when it came to leaks unless it was absolutely the last choice. I am sure my steelflex will chip somewhat but I am fine with that. So will paint. I especially would not put epoxy on the inside of my boat.
