Troutman3000
sixshootertexan said:One more question.
Is it necessary to apply 2 coats?
Two coats are better than one.
Howard said:I have done the research and have a can of Gluv-it in the garage. I plan to use it but for a different application. No doubt this is a good product and will seal leaks. For me, when it comes to water penetration I will look for the best permanent solution. I guess after my battles with water penetration, industrial, commercially and residential, my experience tells me to attack the problem from the outside in and not the inside out. At times my thinking is not economical or practical but it normally is a one time fix.
cactusjack said:Adding tint? I have read this entire thread and noticed a few people mention you can add whatever tint color you may want from Home deport or the like. Does anybody know how much would need to be added and are the tints used at the big box retailors compatible with the steelflex? Do they use different tints for different paints or are they all the same. Thanks in advance for any info
cactusjack said:cactusjack said:Adding tint? I have read this entire thread and noticed a few people mention you can add whatever tint color you may want from Home deport or the like. Does anybody know how much would need to be added and are the tints used at the big box retailors compatible with the steelflex? Do they use different tints for different paints or are they all the same. Thanks in advance for any info
To answer my own question and for others I went by HD and Lowes yesterday and asked about adding their tint to the steelflex, both places advised it was a no-go and advised me I would have to go to a marine shop that dealt with paints. Has anypne ever had tint added at HD or Lowes? I may try Ace Hardware since they seem to be a bit more personable.
dave shady said:Is it safe to use "PLASTIC" bun glide sliks with a steel flexed hull not to mention a rivited hull?
Not sure about Gluvit question, but I just ordered 2 gallons to do my entire 12 footer inside and out. I'm figuring on having extra when I'm done. I would definitely recommend calling and talking with Jerry @ Fasco. He seems like a good guy and will point you in the right direction.Mojo^ said:I just spent a good hour reading through 11 pages of posts and I want to make sure I'm reading this correctly.
I have a 1442 jon boat so I will probably need 2 gallons of steelflex to cover the entire boat inside and out. Correct? Can steelflex by used like a final paint top coat over Gluvit?
