CedarRiverScooter said:I am going to make a couple assumptions - your trailer/boat is balanced for correct tongue weight,& the existing bunks are old. That said, why not buy new 2x4s & some cheap I/O carpet & throw the old ones out? Then you are set for 10 years before they rot out.
Frankenfish said:Is there anything wrong with having bunks extend an inch past the transom? Maybe a couple inches to use it as a step at the back of the boat?
onthewater102 said:Take a straight edge to the bottom of the boat...if it's not hooked under and concave in the area at the end of the supports and it's been on that trailer forever you're probably fine.
If you've got a hook in your hull you definitely need them extended to prevent further damage.
