mmf said:
I remember your post now, you had the salt water corrosion. You are going to find alot of GROUNDING problems on that motor due to the electrolosis.
Hey mmf, thanks for the links and advice. I actually got the motor going today! Either I got lucky, or there was just a loose connection somewhere, because all I really did was basic stuff like replacing the plugs and checking wires. I had the muffs on the motor while it ran, and I just let it idle for about 30 seconds until I shut it off. I know you said I need to remove the exhaust cover and do some work on it, but I am not mentally prepared for possibly snapping off any bolts, so I am saving that for later. I moved directly to dropping the lower unit and replacing the impeller. I've been stuck before due to a bad impeller and I'm not going through that again. Even though it looks good, I'm replacing it. I took a few shots of my progress today. None of them are pretty...and I didn't even take a picture of the wasp nest that had been built inside the motor....but each picture shows progress being made.
This is the second time I've removed a lower unit, and it was still a PITA, but it went much smoother than the first time.
The impeller looks good, but it's going to be replaced anyway.
A little dry and rusted, but okay otherwise.
The wiring for the trolling motor is ready and waiting for me to stop screwing around and get this boat on the water. Thanks to the people who recommended genuinedealz.com as the place to go for wiring. They were great to deal with. I also have a "dash" which is a custom cut cutting board from https://www.cuttingboardcompany.com. No pictures of that right now, but I think it's going to be nice. And I guess while I am at it, I will mention that I purchased a switch panel from Gander Mountain. All kinds of things still to do on this project, and the holidays are coming up fast.
