atb
Thinking of using 4 1x1x1/8 square tube aluminum toggle bolted to the front deck, then supported in the rear by vertical aluminum tube mounted to the support ribs. The front of the seat support is causing the problems. I saw one of the guys mod and they used 2x4s and made kind of a fork with a v angle at the bottom for support which was great but I would like to keep it all aluminum. I was thinking of using super marine adhesive and gluing some square tube in the rib and run from side to side for support a 18 inches in front of the bench. Anyone see any issue with that or have any better ideas?
Thanks in advance.
Thanks in advance.
