I'm not a hippy-treehugger, but running my newish-to-me motor in a tank at home (50 gal. trash barrel) was a little eye opening on just how dirty a 2-stroke motor can be. I understand that running a 2-stroke at idle is not running it at peak efficiency, but the oily scum that ended up floating in the top of that barrel was stomach turning. Plugs are new, gas is ethanol-free from Mobil, oil is Quicksilver mixed at the correct ratio. This engine does smoke some when it is running. Should I suspect something isn't running right, or is this to be expected from a 1986 Mercury 2-stroke running at idle?
Other than replacing the motor with a 4-stroke, I'm researching other ways to help a 2-stroke outboard run cleaner. I know there is a lot of debate over oil, but I would be interested in knowing if others are running something different (at different ratios) and what their experiences have been with smoking and any kind of discharge in the exhaust?
Thanks!
Thanks!
