If you want to cleanout your outboard from all the carbon buildup, use Seafoam...that is what it is made for !! Add to fuel, then run engine and spray into carb until engine stalls. Let it set at least 15 minutes. Then with a heavy dose added to the fuel, fire it up again but be prepared for a smoke fest !! It will look like the whole neighborhood is on fire !! It is burning up the carbon deposites rhat were dissolved by the seafoam. Done this many times, just be prepared if your neighbors call the fire dept !!
As far as AutoZone brake pads go, yes they do have lifetime pad replacement if you plan on keeping the vehicle for a long period of tiime. They are twice the cost, so you need to plan on a long time to get you moneies worth. I had a Blazer for 6 years, it was totaled in a crash, replaced it with another Blazer, same year. Had that one for 8 years, bought the lifetime pads, never bought another set in all those years....but...you do need to return the old wornout pads for a new set, they don' t just hand them out and yes, the reciept as well.
Thanks airshot. I appreciate the brake pad advice but I have warped rotors as well. My truck has some upgrades and the brakes need to be upgraded as well. I have a brake kit coming for all four wheels from Power Stop.
The last time I tried decarbing I had a can of CRC marine engine tune and decarbonizer. I found a spot off the main lake and was in the reeds. Fallowing directions I had it warmed up and started spraying it each of the three carburetors and when it would bog I would give it a little gas to keep it running.
Supposed to use he whole can but after about half I looked around and all I could see was smoke EVERYWHERE! I thought man I’m going to get into trouble out here. Luckily it was during the week and the lake wasn’t crowded. But after idling my way out of the cloud of smoke I took off and ran to the other end of the lake.
After a bit I thought I’d better go back Incase someone was concerned what happened I was going to confess.
Nobody there but the reeds where still full of smoke with a big floom in the air. There was no wind that day. I wasn’t far from the power plant intake.
I can laugh about it now. I could tell a small difference in the engine but I hadn’t finished it.
When using Seafoam should I run on muffs? If in a barrel I’d be circulating all that gunk through the cooling system I think.
Ive seen the spray cans and bottles of Seafoam together is that what you’re talking about? Or should I buy the marine Seafoam?
I’ve seen what they call a shock treatment where they use a one gallon gas can and a whole can of Seafoam then disconnected the fuel line and stuck it in the gas can.
I like what you’re suggesting better.
Do I run it until it stops smoking? Then go to the water with fresh fuel or run an entire tank of strong Seafoam? Also am I just idling the whole time or do you raise the rpms any?
Sorry for the hundred questions I just want to be careful running muffs and my rpms. Heard to many horror stories about running on muffs to long.
I get way better water pressure in a barrel with a hose constantly running fresh water into it. Goes through a lot of water but I know it’s getting plenty.
I bought four sets of muffs before I found some round ones it’ll run on and I secure those with a clamp I rigged up or they vibrate loose. According to the telltale it’s circulating plenty of water and I use a ir thermometer to keep an eye on it.
Thanks again for your help.
