Cool idea with the hose clamp and nut thing. Main thing there is to make sure the nut is very tight fitting so it won't turn inside of the plastic hole. But, I can't think of anything else that would work any better.
Someone's already removed the knob and replaced it with a bigger bolt which was also already stripped out when I got it. But, I can take the tension knob out of the Endura 55 model, which is now gonna be used for parts, and use it on my Endura 36 I reckon. HHmmmmm...I wonder how much trouble it would be to just swap out the whole mount assembly and shaft holder from the 55 and use it with my 36? Looks like I would have to remove the control handle assembly from the top of the shaft so I could slide it into the shaft holder, right? Is that an option, or would it mess up the handle assembly?
Thanks, man!
