Colorado1135
I have a Fisher avenger pro 19 and it lists bad to port when on plane. I have a 99 kicker on the stbd side but that doesn't seem to make a difference, moving adults to one side does help. boat sits level in the water so it doesn't make any sense. That aside I've decided to install trim tabs for a better ride, downside is there isn't room where the kicker is mounted. I'm thinking about putting on a mini jacker plate to set it back to make room. does anyone see any issues with this? does anyone have a plate they don't need before I order one? I figured I'd check here after searching the interwebs off and on the last few months. also, if anyone has any suggestions on what kind of tabs to get I'm all ears. TIA
