flajsh
Hey big.
You mentioned going to a service center for a motor.
do you know of a good one in our area.
John.
John.
Too funny, it only takes money, which mine is real tight right now. It took me a while to realize that rushing this mod is not the way to do it. I have a whole box full of stuff just waiting to be installed, bilge pump, livewell pump, lights, wires, etc. I know that where I am at on this build is the most important. I plan on working on the boat all day sunday, and should make some more progress. Hopefully no one asks me to go fishing this weekend....keeps getting in the way of my build.flajsh said:At least someone is making progress.
I haven't had much time for mine.
MrSimon said:I just got a bunch of road signs from the local township buildings scrap pile, and they are all exactly .9" thick. I laid them out on the floor of my basstracker and walked around to get a feeling for how sturdy they are. I'm about 200 pounds and I figure I want a MAXIMUM of a 12" gap anywhere to avoid sagging and bending.
I suppose once its all put together and riveted down, maybe I could get away with larger gaps, but why push it.
xbacksideslider said:How much lighter is .090 aluminum compared to 1/2 plywood? Not much I'd bet. If you go to .063, then yes, maybe 20 pounds lighter per sheet.
It's more about how you want to build it than weight.
Aluminum is more difficult to fabricate, but a superior material for this application. Wood is cheaper both as a material and to fabricate.
Nice job, I like your project.
flajsh said:Is there a way to deaden the sound from aluminum flooring or is not that much.
cause I was considered using that also.
Hey big. One of these days I may have to pay for gas and bait so you can show me how to catch
a dam snook.
Lmao theres the name of my boat.
Snookless.![]()
Even if I don't use aluminum for the decks, the 4x8 closed cell sheets are probably going to be what I use. For the price and ease of use this seems practical to me. I like the two part foam but it is too much money for me. I might just go foamless for a while. This will only be temporary, when I am shaking down the boat. I want to make sure all wiring and accessories work before I go and cover with any type of foam.xbacksideslider said:4x8 sheets of construction styrofoam are about $10 per and a spray can of contact cement will stick them together and to your aluminum sheet.
For below deck or to build it up from the V to a flat surface by careful cutting and selection of thicknesses of the foam. It cuts easily freehand with a simple hack saw blade.
As for yor storage areas that have aluminum decking above, the styrofoam sheet can be stuck up under your deck with the spray contact cement as well
That should deaden sound quite well.
