Big - Got anymore Updates
bigwave said:Thanks Johny25, It is pretty easy to drill the ribs, you just have to take it slow so you dont punch through the hull. I only had a few of the braces with rivets in them and it was already feeling strong. Super light too. I plan on getting a fiber blade with no teeth,just like the one on my grinder only thicker. It is pretty easy cutting with the grinder but its hard to get a flush plumb cut. I should make some significant progress now that I have figured out how to attach all the aluminum. Thanks to johnboatjerry.......got the idea from his build. On a side note I just found a place that will sell me 1x1 square tube in 24 foot pieces for 30 bucks......they are a hell of alot cheaper than Homedepot. Town and country industries.....great prices on aluminum.
Bigbigwave said:Well even though Sunday was mother's day, I did manage to get some more framing done. Just a few more sticks of aluminum and I will be done. After some advise I am considering going with .090 sheet for the main deck and the front and rear casting deck. The price has to be right or I will go with my original plan of 1/2 plywood.....the weight difference is real tempting even though it might cost double.....Oh well still have time to think about it.
Gonna steal your floor framing most likely that's why I was wondering. How many feet of angle did youbigwave said:The way it is right now is very solid.....I might put a few more braces between the long runs on the bottom deck....I have been holding out on the decking since I want it to be aluminum. I put a small piece of plywood down on the deck area and It felt real solid. On the upper decks there will be vertical pieces of plywood to carry the load of the decks. I will have two side lockers running between the casting decks, port and starboard....this in theory should stiffen up the entire boat since I can attach at multiple points and pull the sides in......I hope to stand on these lockers too.....we will see. Hey did you get a good deal on your motor? My family has gone back home, so now I hope to work on the boat this weekend.....still have a ton of stuff to do.
bigwave said:Well I got just a bit more framing done. I thought I would post up a couple of pics on how I am attaching my joints on the aluminum framing. I have a quick question for anyone who has used aluminum sheet for their decks. PSG-1, Bugpac, Bassboy, or anyone else. I am thinking about using aluminum for the decks....
1. How much bracing should I use for adequate support for the decks. As it stand now there will be support bracing 11 1/4" from the center line...will this be enough to put sheet aluminum on the main deck without flex or bows?
2. What gauge sheet? What can I expect to pay for the standards sheet size, and what sizes are available for the sheets?
