PSG-1 said:Wow, amazing work, mmf! Hadn't noticed this thread until just today, as there was a new post to it. I checked it out from page 1, and I have to say, you've got a good bit of time and effort in that boat, but it really looks good! =D>
BTW, here's a useful bit of info: if you're cutting aluminum with a circular saw, you need a "Diablo" blade. It will make the job much easier. You should be able to find one at a Lowe's or a Home Depot. They are red in color, and they are about half as thick as a regular circular saw blade, which equals a smaller kerf, but more importantly, it also means there is less resistance on the motor of the saw, which equals faster cuts with less effort. If you are cutting 1/8" plate, get the fine tooth type. But on thicker aluminum, like 3/16 or 1/4", get a more coarse tooth, like a framing cut blade. These diablo blades are simply awesome for cutting aluminum.
Cold night here on the SC coast, too, gonna be 34 degrees tonight. Still a little too warm to fire up the snow guns, but cold enough I have the wood stove going. Well, considering turkey day is next week, it's about time for some cool weather here. Happy Thanksgiving to you and your family, too!
Can you use these blades with a miter saw?
