mmf
Derek said:I don't know how much smoke you are getting but mine smokes a lot more on start-up but usually cleans up within a minute. Wouldn't the bad piston rings shown up on the compression check, if that was the problem?
Yep, piston rings would show up, that's why I said "motor ran good" at high speed, it would not have otherwise, just talking to myself in reasoning out the problem, thanks Derek.
I found the problem today after checking trigger resistances, trigger output, stator resistances, and stator output. Then I checked running (firing) voltage to the coils and all was in check, cranked skipping motor back up and started pulling plug wires while it was running and #3 (bottom) cylinder made NO difference in idle speed. This coil checked "good"on resistances, primary and secondary so, it must must have been firing across the winding inside the coil but NOT firing across the gap on the plug. It would even fire my inductive timing light, but it failed the spark test (very weak), good, I was really hoping it was not the power-pack not switching properly and it turned out to be the coil. I replaced it and #3 started firing good.
Even though the spark plugs were new when I started troubleshooting the motor, I ran a bunch of Sea Foam thru the fuel system and block which loosened alot of carbon etc. and stuck to the plug insulators while doing so, so I will buy new ones to replace them.
FYI....OMC calls for L78V plugs (surface gap) for continued HIGH SPEED operation on this motor, which will be the case on this motor. Troll motor will come into play after getting to an area to fish after the"run". This motor had the slow speed plugs (QL77JC4) installed which foul a whole lot easier in my book, at least that's been my experience.
I also noted that the QL77JC4 plugs have an internal resistance of 125 ohms which can reduce the fire to the tip, but reduce the noise and (RFI) generated to radios, depthfinders etc., while the L78V plugs have NO resistance, myself, I would rather have a hotter fire. I can put a filter on my electronics if there is a problem.
Got to move the tranducer up on the bracket, and reverse the sector shaft bolting on the steering helm and I will be ready to try again, wish me luck!
