Derek
Your trailer looks great. Have you checked to make sure the jack and winch handles don't hit? Mine barely clears and it looks farther away then yours.
Derek said:Your trailer looks great. Have you checked to make sure the jack and winch handles don't hit? Mine barely clears and it looks farther away then yours.
mmf said:I am on pause because my mother who is 90 years old is in the hopital.
mmf said:Thanks Darek, no the winch and jack handles are OK, at only one point are they close, but think about it, you really won't jack up the trailer until boat is loaded and back in it's parking place at home (at least in my case) so the jack will be folded out of the way of the winch when loading the boat, even if it did hit, it would be easy to move the winch handle where you needed it on land. Thanks for the reply!
Derek said:what paint remover are you using? I plan to repaint mine at some point so it would be good to know. Did you use a heat gun to peal the stickers off? I was thinking the heat would help loosen the glue.
albright1695 said:Light brackets look great. As usual ,very professional looking. Nice!
